Architect or LandmarkCreating hardscape objects
Concept: Hardscape types
For 2D plans, select a boundary or pathway configuration.
For 3D designs, a variety of hardscape configuration and types are available. Select the one that best suits the needs of the design.
Hardscape
Suggested purpose
3D Type: None
For less complex designs, and when none of the other types is necessary, this provides a good default solution. Select None when:
There is no need for the hardscape to have a thickness for 3D views or sections.
There is no need for components, for either rendering or reporting purposes.
A particular style of hardscape or manufacturer is not required.
The hardscape does not need to serve as a modifier for a site model.
Slab drainage functionality is not needed.
The slab can remain completely planar.
The slab does not need to automatically match the elevations of any other objects.
3D Type: Slab
Select Slab when:
The hardscape needs a thickness or components for 3D views or sections.
Components are required for rendering or reporting purposes.
The hardscape needs to modify the site model (optional).
3D Type: Slab Drainage
Select Slab Drainage when:
The hardscape needs to support a drainage system or you need to create simple non-planar geometry for the hardscape
Use site modifier
Select Use site modifier when:
The hardscape will serve as a modifier for the site model.
Configuration: Planar Pad
Select Planar Pad when:
The hardscape is used as a site model planar pad modifier; see Creating a planar pad or pad with retaining edge.
The hardscape needs to interact with other modifiers (depending on nesting, overlapping situations, and creation order).
Configuration: Aligned
Select the Aligned configuration when:
The hardscape modifies the site model, and it needs to vertically match the horizontal edges of certain geometry, including adjacent roadways, hardscapes, massing models, 3D polygons, landscape areas, walls, and planar pad or pad with retaining edge site modifiers. Aligned slabs are complex, non-planar hardscape types that can also be modified with vertical profiles, stake objects, and grade objects. See Creating an aligned site modifier.
Configuration: Path
Select the Path configuration when:
The hardscape is used as a site model path modifier; see Creating a pathway or boundary modifier.
The hardscape needs to be modeled as a path, with a specific longitudinal profile and transverse profiles; the path shape can be widened or narrowed as needed using the Reshape tool.
Creating hardscapes
